Clauram
Apr 14, 2021Follower
C6300 Can’t access routerlogin.net
Hi,    I need to update my wifi password which I was able to do through routerlogin.net previously but the website doesn’t seem to exist and the net gear pages throw me into a loop with no actual solu...
antinode
Apr 15, 2021Guru
> There is no "website" as most people understand it. [...]
   By "most people", he means himself.  But, in any case, a description
like "the website" or "the net gear pages" or "the net gear website
[...]" is too vague to be useful.
sato-yuichi-887
Apr 17, 2021Tutor
I don't see your reply to my latest insult, which was written in 2021-04-14 22:28 PST. Perhaps you did write one, but it got filtered without you knowing. Can you see it in a private browser window (or Incognito Mode)? If you can't, then I can't.
- michaelkenwardApr 17, 2021Guru - Experienced User
 sato-yuichi-887 wrote:
 I don't see your reply to my latest insult, which was written in 2021-04-14 22:28 PST. Don't waste your breath. As you can see, antagonism mode is permanently turned on over there. Stick with trying to troubleshoot your problem. Swapping insults is a waste of everyone's time. There are still a lot of unknowns about what is going on at your end. Here are some pointers: How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support and this: If you cannot login to your router | Answer | NETGEAR Support Then there is the "loop with no actual solution". That too is thin on details. Here is another one to try to elicit more information from you: There is a bug in Netgear's implementation of password recovery on some devices. You can get locked into a closed loop. Is this what you mean?
 If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct.
 If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
