Clauram
Apr 14, 2021Follower
C6300 Can’t access routerlogin.net
Hi,    I need to update my wifi password which I was able to do through routerlogin.net previously but the website doesn’t seem to exist and the net gear pages throw me into a loop with no actual solu...
DCH1949
Jun 29, 2021Aspirant
One member suggested using Firefox instead of Chrome and type in the IP address 192.168.0.1. It worked.
- michaelkenwardJun 29, 2021Guru - Experienced User
 DCH1949 wrote:
 One member suggested using Firefox instead of Chrome and type in the IP address 192.168.0.1. It worked. That is a standard strategy that Netgear mentions in its KnowledgeBase article: How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support and this: If you cannot login to your router | Answer | NETGEAR Support You will also find this in the manuals for most devices. I chip in only to point out that the exact address depends on the device you are using. 192.168.0.1 tends to be a modem address while for routers it is 192.168.1.1. Some devices, plain cable modems for example, can have 192.168.100.1 as a default. As this section of the Netgear community is supposed to be for routers, rather than the modem router mentioned in the subject, I wouldn't want anyone to rush off on a wild goose chase. - antinodeJun 30, 2021Guru> One member suggested using Firefox instead of Chrome [...] Did that change matter? > [...] and type in the IP address 192.168.0.1. [...] As suggested in the first reply, above?
 > 192.168.1.1."192.168.0.1" was the norm for a modem+router until recent models,
 like the CAX series, which also use "192.168.1.1". (I haven't seen an
 explanation for the change.) A simple modem tends to use neither
 "192.168.0.1" nor "192.168.1.1".A DOCSIS (cable) modem or modem+router should be accessible at
 "192.168.100.1", even when in modem-only mode.
 The DM200 DSL modem+router, when in modem-only mode, should be
 accessible at "192.168.5.1". (Dxxxx DSL modem+router models have no
 such feature.)
