timwipod
Nov 13, 2021Aspirant
c7000 modem opening ports for tmobile cellspot UDP123, 500, 4500
I found this community very helpful and did many steps, but still not working. Problem: LAN wired the Tmobile cellspot and early step asks to ensure ports UDP 123, 500 and 4500 are opened. Doesn't ...
- Nov 15, 2021
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
Nov 15, 2021Guru - Experienced User
Thank you.
