Ciema
Nov 08, 2021Follower
C7000 resets itself to factory settings.
It happened four times past two months and it is annoying. Did anyone experience similar trouble? It resets itself randomly to factory settings. Checked power wires and reset it with a reset button o...
Nov 09, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
