xwjjjw
Nov 24, 2020Aspirant
C7000v2 AC1900 Wifi Cable Modem Router Slowing Network Speed
I have been using the router as the title mentions which I bought from Amazon since I moved in my new house in March, 2020. Between March and September, I was using a 100Mbps xfinity plan but the wir...
xwjjjw
Hi,
Please find the event logs in the attachment.
I don't think I have any splitters, amplifiers, or attenuators in line. The xfinity agents confirmed that the signal out of the wall and the signal right entering my house are the same. And all the other devices like cables are stable. If I switch to use a tp-link router, I can get 300Mbps. So I think this should be Netgear router issue.
Nov 24, 2020Guru - Experienced User
You logs indicate that its failing to aquire a signal from xfinity and issues with the signal.
It could be the line, cmts, or it could be the modem.
