vdm1245
Mar 26, 2021Follower
C7000V2 getting slow wireless speed
I recently upgraded my comcast/xfinity service plan from 200mbps to 600mbps. When I was at 200mbps I would speed test wireless on my Note20 Ultra 5G at 240+ mbps. With my plan now at 600 mbps I ...
Mar 27, 2021Guru - Experienced User
Problem isn't the c7000 or the phone.
the problem is misunderstanding of the wireless modem/router that you have.
The C7000 is an AC1900 modem/router combo device. Because its a combo devices, its not going to have the same performance as a standard AC1900 router as some of its power and cpu process is needed for the modem side. It was released in 2015 and is a docsis 3.0 device.
Comcasts new modem (XB7) is an AX router (which the note 20 ultra supports). so its a generation newer on wireless standards as well as its going to have a faster processor than an older generation modem/router combo device. 5 years in cpu and wireless standards/performance makes a significant difference.
A fair comparision for comcasts new modem/router (XB7) device is the CAX80.
The speed that you're getting from the C7000 is about the max that you can expect from that modem/router.
