elb85
Nov 05, 2020Guide
C7000v2 Nighthawk AC1900 Cable Modem Router - Extremely slow upload speed
I'm hoping to get some insight. I have the C7000v2 Nighthawk AC1900 Cable Modem Router. Xfinity service - 1000mbps download/35 mbps upload plan The Nighthawk app under Wifi Analytics ->...
- Nov 05, 2020
they either need to check the amp, the line again, or the tap. you have a lot of dynamic range window violations which is when power goes out of spec. Plus t3 errors.
I'd remove that amp and see how it does.
Nov 05, 2020Guru - Experienced User
elb85
Nov 06, 2020Guide
So I ended up bypassing the amplifier and that did the trick. I did also end up going back down to a 300/10 Mbps plan because you were correct in that Comcast requires Docsis 3.1 for gigabit and it might have been a secondary issue.
Appreciate the help.
- plemansNov 06, 2020Guru - Experienced User
Glad to hear you got it resolved!
Let us know if you have futher issues and we're happy to help
