elb85
Nov 05, 2020Guide
C7000v2 Nighthawk AC1900 Cable Modem Router - Extremely slow upload speed
I'm hoping to get some insight. I have the C7000v2 Nighthawk AC1900 Cable Modem Router. Xfinity service - 1000mbps download/35 mbps upload plan The Nighthawk app under Wifi Analytics ->...
- Nov 05, 2020
they either need to check the amp, the line again, or the tap. you have a lot of dynamic range window violations which is when power goes out of spec. Plus t3 errors.
I'd remove that amp and see how it does.
elb85
Nov 06, 2020Guide
So I ended up bypassing the amplifier and that did the trick. I did also end up going back down to a 300/10 Mbps plan because you were correct in that Comcast requires Docsis 3.1 for gigabit and it might have been a secondary issue.
Appreciate the help.
Nov 06, 2020Guru - Experienced User
Glad to hear you got it resolved!
Let us know if you have futher issues and we're happy to help
