CJ_Does's avatar
CJ_Does
Follower
Jun 08, 2021
C7000v2 not reaching full download/upload speed
Recently upgraded my internet speed through my provider. I should be getting 300mbps down over wireless but only get it over Ethernet.
I get around 150 via wireless. Any suggestions on how to speed the wireless up without doing a reset?
I have too many devices connected to my network and it would take me a day to set everything back up if I did a factory reset.
  • plemans's avatar
    a couple things.
    1. wireless isn't as fast as wired.
    2. 2.4ghz is a slow network. ensure your testing over 5ghz. its still not going to be as fast as wired but it'll be faster than 2.4ghz
    3. what device are you testing on? a 1x1 client is going to have half the speed of a 2x2 client
    4. how far from the router is the device you're testing on? and whats in between the 2?
  • michaelkenward's avatar
    michaelkenward
    You do not need to change anything on your wifi clients if you give the C7000v2 the same SSIDs and passwords as it had before the reset.
    As plemans suggests, that's not bad for many wifi clients. Put it another way, your router can deliver wifi at a gazillion miles an hour but wifi clients stuck in the slow lane will still crawl at a snail's pace.
