Retired_Member
Jul 31, 2021C7100V Cannot duplicate 2.4 and 5 ghz SSID
I have a C7100V that I've used for years. My setup has the SAME SSID for 2.4 ghz and 5 ghz wireless and it worked great with all my devices. This cable modem/router was recently damaged by power s...
michaelkenward
Aug 01, 2021Guru - Experienced User
Retired_Member wrote:
....so I replaced it with another (used) C7100V.
I assume that you reset the "new" device" to get it forget any old settings.
but if there is a way to put the "new" unit in the same configuration as my previous unit, I'd like to know how.
Do you have a backup of the settings on the previous modem/router? You could try reloading that.
I get an error message and it reverts back to the previous setting each time I try.
Error message where? In the browser graphical user interface?
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
That is where users of these devices hang out.
