Bodhi22
Feb 08, 2021Aspirant
C7100v modem/router turn wifi back on
Hi, I have disabled the wifi on my c7100v modem router. If I want to enable the router wifi how do I do this? There is no physical button to turn the wifi back on. Because there is no wifi I c...
- Feb 09, 2021
Hi,
>As described in the User Manual under "Set Up the Modem Router in
>Bridge Mode"? That does a little more than "disabled the wifi".Yup. It sure does.
>As it also says in the User Manual under "Set Up the Modem Router in
Bridge Mode":> Note: When your modem router is in bridge mode, use
http://192.168.100.1 to log in to your modem router.Yes, I read other threads in the community about using http:// to log into the modem/router when in bridge mode. I will give this a try.
>As usual, the actual message text might be more helpful than your
>interpretation of the actual message text.> [...] My wifi mesh router [...]
>Not a very detailed description of that device.
> [...] was connected as well [...]
>To a LAN Ethernet port on the C7100V? I'd guess that that was the
>one device which got the one valid IP address from your ISP (leaving
>none for your (unspecified) "my laptop").
> [...] so I am wondering if I should disconnect it and retry accessing
> my modem with my laptop?>Yup.
>With the C7100V in modem-only ("bridge") mode, only one client device
>should be connected to its LAN ports. If that one device were your
>(unspecified) "my laptop", then it might get a valid IP configuration
>from your ISP, and, if you then specified the suggested IP address
>("192.168.100.1") in your web-browser URL, then you might reach the
?C7100V management web site.Makes sense, I will unplug the ethernet cable (from my mesh router) on the modem router and plug in my laptop.
>In the worst case, you might need to configure the Ethernet interface
>on your (unspecified) "my laptop") with a static address like
>"192.168.100.X" (1 < X < 255).>Or you could take what might be the easy way out, and do the settings
>reset (see "Factory Settings").Defintely will be my last resort!
I'll keep you posted,
Thanks!
antinode
Feb 09, 2021Guru
> In Router Mode there was a check box with "yes" or "no" I selected
> "No"
Bridge Mode":
> I connected my laptop [...]
Not a very detailed description of that device. Windows? Mac?
Other?
> [...] to the modem with an ethernet cable [...]
And configured its Ethernet interface how, exactly?
> [...] got a message saying I could not because my IP address was not
> recognized. [...]
Yup.
Bodhi22
Feb 09, 2021Aspirant
Hi,
Yup. It sure does.
Bridge Mode":
>Yup.
Thanks!
- Bodhi22Feb 09, 2021Aspirant
Okay, so I was able to access my modem/router over wifi using 192.168.100.1. On the setup page under "Advanced" there was an option to turn router on or off.
All is good,
Thanks!
