BobKein's avatar
BobKein
C7800 - Ethernet port : routed or not?
Hi,  I am considering buying the C7800 to use with Spectrum. I am trying to figure out how are the ethernet port on the C7800 managed? Are they behind the router and as such connected devices will ...
  • plemans's avatar
    Apr 28, 2021
    I take it you must have had the CM1200. It creates confusion with people.
    The C7800 is a modem/router combo device and not just a modem device. (it can be set as modem only though but then only 1 port would work)
    the C7800's lan ports are just that, lan ports. You can connect devices to them.
