6Mill
Jan 27, 2021Aspirant
C7800 Nat Mode and Bridge Mode
Hello, my internet provider told me I should enable bridge mode on my c7800 because we have ERRO whole home wifi. However, when I go to the router login, under advanced-administrative there is no bri...
6Mill
This is not an for me under advanced-administrative on routerlogin.net for some reason
6Mill
Option*
- plemansJan 27, 2021Guru - Experienced User
I don't have my C7800 at my location (at in-laws). I'd have to wait to see what mine shows the next time I'm there.
You could always put the eero's ip address into the netgears DMZ. That should auto forward info.
You can also disable the wifi if you wanted or use it as a backup.
