Fordineaux
Jan 09, 2021Follower
C7800 seems to be stuck rebooting
Hi all, I just got a refurb C7800 AC3200 and I'm trying to see if it needs to be sent k. I went through the xFinity app process to switch to this router from the gateway, and it seemed like mayb...
michaelkenward
Jan 10, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
I will ask the Netgear moderator to move your message.
