Cokes
Jan 14, 2022Follower
C7800
CAN I ADD A MESH SYSTEM TO THE NIGHTHAWK WIFI CABLE MODEM ROUTER?
1 Reply
You can if you disable the wifi radios on the modem and put the MESH into AP mode.
Or you can add WiFi extenders to the modems wifi signal.
Or you can put the modem into modem only mode and install a MESH system in router mode.
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
