jkgonzal
Dec 08, 2021Follower
Camera system
I have trying to work on security system. It has a camera 1/2 mile away. I need a access point that will go that far and a recover that will send the camera signal back. What do you recommend Jame...
Dec 08, 2021Guru - Experienced User
Half mile away. Ya, thats a bit of a range thats too far for home class routers and wifi APs.
I recommend you find a camera that is wired or set with a on site security system. Contact the Mfr of these cameras for there help and information on what suggestions could be used for remote distance cameras.
