Yerffejnuarb
Feb 10, 2023Aspirant
Can’t connect to original SSID after factory reset
Hi. All of a sudden I couldn’t connect to my 2.4 or 5G Wi-Fi signals. I ruled out my ISP and modem - they were fine. The router’s SSID’s were visible but ultimately couldn’t connect to them. I did a f...
Feb 10, 2023Guru - Experienced User
What firmware are you running?
did you recently upgrade?
You can try downgrading a version and see if it helps
- YerffejnuarbFeb 10, 2023AspirantAfter my original post, I just updated to firmware version V1.2.0.92_1.0.1 (before this point, it was saying I had the latest firmware). Problem is persisting, although I narrowed it down a bit. After a factory reset, here is the sequence of steps before I get stuck
1) change 5G SSID and password back to original - no problem
2) change 2.4 SSID to original leaving the passcode alone (keep the default password from factory reset). No problems.
3) change my 2.4 passcode to my original one - now can no long connect to both 2.4 or 5G signals. they are visible, just can’t connect. Only option from there is factory reset again.- plemansFeb 10, 2023Guru - Experienced User
Have you tried a new device to connect to it?
- YerffejnuarbFeb 10, 2023AspirantYes. Multiple phones and computers.
