Yerffejnuarb
Feb 10, 2023Aspirant
Can’t connect to original SSID after factory reset
Hi. All of a sudden I couldn’t connect to my 2.4 or 5G Wi-Fi signals. I ruled out my ISP and modem - they were fine. The router’s SSID’s were visible but ultimately couldn’t connect to them. I did a f...
Yerffejnuarb
After my original post, I just updated to firmware version V1.2.0.92_1.0.1 (before this point, it was saying I had the latest firmware). Problem is persisting, although I narrowed it down a bit. After a factory reset, here is the sequence of steps before I get stuck
1) change 5G SSID and password back to original - no problem
2) change 2.4 SSID to original leaving the passcode alone (keep the default password from factory reset). No problems.
3) change my 2.4 passcode to my original one - now can no long connect to both 2.4 or 5G signals. they are visible, just can’t connect. Only option from there is factory reset again.
Feb 10, 2023Guru - Experienced User
Have you tried a new device to connect to it?
- YerffejnuarbFeb 10, 2023AspirantYes. Multiple phones and computers.
- KitsapFeb 10, 2023Master
Yerffejnuarb wrote:
Yes. Multiple phones and computers.Have you tried simple alphanumeric strings for both the SSID and the pass-code? Make sure to use no spaces, punctuation, or special characters for either.
- YerffejnuarbFeb 10, 2023AspirantI’m trying pretty hard to maintain my original SSID and passcode so that I don’t have to reconnect the several dozen misc things I had previously connected to it (smart home stuff, media players, cameras, etc). Worst case scenario I just use a different SSID that works just fine. Just mystifying me on why I can set it to what I had before I did the factory reset.
