BunniRabbid
Apr 30, 2022Guide
Can’t find router
Through today the routers light has been orange and the app says it can not be found. Even when trying to do a set up after a factory reset. Originally the satellite light was blue but after the fact...
May 01, 2022Guru - Experienced User
So that NG model router system do you have?
What app are you referring too? Mobile app or routers web page?
Screen capture would be good to see what your seeing as well.
Originally the satellite light was blue but after the factory reset it is now orange.
During the set up it keeps checking cables but ends up coming up with an error.
