SherryX
Jan 19, 2022Aspirant
Can’t find the router
I can’t find the router in my wifi list anymore after I power off/power on my AX4300. What to do?
Jan 20, 2022Guru - Experienced User
What router do you have? AX4300 is a speed.
What modem is it connected to?
What firmware is it running?
What are the wifi led's on the router showing?
Did the wifi on/off button get hit? push and hold it for 2 seconds
- SherryXJan 20, 2022Aspirant
Thanks for your reply. I reset it. It works now. Just so strange, the wifi disappeared suddenly. Before I reset my rounter, I saw a very strong new wifi in other names appeared in my wifi list. But my passport didn't work. Was my wifi been hacked at that time?
- michaelkenwardJan 20, 2022Guru - Experienced User
Reset 0r restarted?
First try to restart the router and your network.
- Turn off and unplug modem (if there is one).
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
