TerryJ40
Apr 17, 2022Aspirant
Can’t get a wireless printer to work on my network
Apr 18, 2022Guru - Experienced User
What router do you have?
What firmware is on it?
What printer are you installing?
Where does it fail in the process? and what errors are you getting
Its tough to help without details
TerryJ40
Apr 18, 2022Aspirant
It installs ok but when you go to print it can't hook up with it
- plemansApr 18, 2022Guru - Experienced User
You didn't really give us anymore details. tough to help without those.
If its a new printer, contact the manufacturer.
If its a new router, contact support.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
