Leslielavender
Sep 07, 2022Aspirant
Can’t remember WiFi password, don’t know how to change
Hi-I first set up my router two years ago, and at that time changed the WiFi name and password to something different than what’s set up on the bottom of the router. I haven’t had any issue until I ju...
Concerned-user
Sep 07, 2022Guide
Sorry you have to deal with this problem. You can factory-reset the router using the reset button https://kb.netgear.com/000038536/How-do-I-reset-my-NETGEAR-cable-modem-or-modem-router . Unfortunately, after the reset you'll have to manually setup the router from scratch.
