__EHH__
Sep 28, 2021Tutor
Can a R7000 in bridge mode communicate with any type of router or just another R7000
Dear ppl, I have 2 routers (both R7000's), one set up as a router and the other as a bridge. All is working well on both 2.4G and 5G (although not simulaneously, as I read it woudnt do). After a ...
Portwey84
Sep 28, 2021Virtuoso
__EHH__ My first suggestion is perhaps you might want to update your routers firmware because you're currently five firmware versions behind the latest for your model of router:
https://kb.netgear.com/000064024/R7000-Firmware-Version-1-0-11-128
If you read through the threads on this forum, you will see plenty of references to the auto update feature which is as reliable as a chocolate teapot. If anything, update your firmware just for the security fixes.
- __EHH__Sep 28, 2021Tutor
Thanks for your suggestion. Strange the f/w is 5 versions behind as I expected the firmware to be up to date as I had the R7000 check for new f/w last weekend and updated it.
If I dont find a solution I try updating the f/w as the bridge is working in my network.
Thanks,
E
- Portwey84Sep 28, 2021Virtuoso
__EHH__ wrote:Thanks for your suggestion. Strange the f/w is 5 versions behind as I expected the firmware to be up to date as I had the R7000 check for new f/w last weekend and updated it.
E
__EHH__ To be honest, I'm not surprised your firmware isn't up to date. The amount of folks that come onto this forum who think their firmware is up to date and post in the belief that it is, has numbered many. As I say, you can't trust what the check for updates button says because it will tell you you're up to date and no updates are available. Netgear it seems, have no interest in resolving that from the experience I've had.
You say you updated the f/w last weekend. I'd love to know what firmware your router was on before you updated, especially as you are currently so far behind, unless you've updated since my last post.
Thanks for your reply.
Hmm you raise an interesting subject.
The f/w the R7000 was using was v.1.0.9.64_10.2.64.
The new f/w as found by the R7000 update procedure was v.1.0.11.120_2.1.38.1 but the f/w that was downloaded/installed is v.1.0.9.88_10.2.8
E
