__EHH__
Sep 28, 2021Tutor
Can a R7000 in bridge mode communicate with any type of router or just another R7000
Dear ppl, I have 2 routers (both R7000's), one set up as a router and the other as a bridge. All is working well on both 2.4G and 5G (although not simulaneously, as I read it woudnt do). After a ...
Sep 28, 2021Guru - Experienced User
I would first troubleshoot the printer not working with the R7000 in bridge mode before updating FW. It should work with the R7000 in bridge mode and the printer connected to the R7000.
Make sure the printer is getting an IP address from the Host router thru the R7000 in bridge mode. If your wanting to connect the printer to the R7000 in bridge mode, you first need to ethernet connect the printer to the R7000 inback. Bridge mode on the R7000 turns it in to a wireless client, not a wifi signal broadcast that can be connected too. While the R7000 is in bridge mode you can only connect ethernet connected devices to the back of the R7000 in bridge mode.
__EHH__ wrote:
Dear ppl,
I have 2 routers (both R7000's), one set up as a router and the other as a bridge. All is working well on both 2.4G and 5G (although not simulaneously, as I read it woudnt do). After a power cycle all was well still.
With the bridge set-up at my home I took it to my dad to have his printer connect via wifi to the network (same networkname and password as at my place) but it didnt work. The proper LED's lid up on the R7000 bridge (the same LED's as with the working situation at my home) but I never managed to get the ethernet networkprinter to work.
The only difference between both situations is the Zyxel router that my father uses where I use another R7000.
I checked the DHCP IP pool to make sure IP numbers arent duplicated etc. (the printer uses a fixed IP address but changing it to a DHCP provided IP address made no difference).
My laptop was able to connect to the wifi network w/o any problems while at my dad's place.
The f/w on both R7000's is V.1.0.9.88_10.2.88
My dad's network consists of the Zyxel router located in the utility closet broadcasting 2.4G and 5G wifi signals. The Printer (HP Laserjet Pro M1536DNF) is in my dad's office upstairs (my mom doesnt allow it to be taken down one floor :-) )
Any suggestions?
Thanks,
Edwin
btw. when I returned home I checked whether the bridge would still work ... it did!!!:smileyfrustrated:
- __EHH__Sep 28, 2021Tutor
Thanks for your reply. I understand that the bridge R7000 only supplies a wired network connection.
My dad just changed from one ISP to another (from ADSL to fiber). In the old situation my dad used his R7000 as a "regular" router with the printer attached to it (via ethernet cable, the printer is not wifi capable). So the printer worked fine for years and years via an ethernet cable connected to the R7000.
E
- FURRYe38Sep 29, 2021Guru - Experienced User
I'd contact the printers mfr for help and support with there product. If thre has been a change on the router or printer in regards to IP addressing, the printer would need to be probably set up again with it's printer driver.
E
