Ravsir
May 09, 2022Tutor
Can a R8000P be configured as an access point to extend a guest network, or just the primary WiFi?
I own an R8000P which I'm having issues with IP allocations and access control, but that is a separate question. To work around this issue I'm looking to use a ds7800 as my WAN interface into an NBN ...
May 09, 2022Guru - Experienced User
the r8000 doesn't have a repeater mode.
You can either set it up as a router, an access point, or a bridge.
- RavsirMay 10, 2022TutorWhich makes it a bit of a dud when it fails as a router.
Am I correct in assuming there are issues with the architecture of extending the networks created by this device when in AP mode? I can't seem to get my ex7700 to connect to it when in this configuration.- plemansMay 10, 2022Guru - Experienced User
You should be able to connect the EX7700 to the R8000 with the R8000 in ap mode.
I've done something similar numerous times with other netgear routers and a EX7300 and EX8000.
You won't be able to use guest network as thats disabled in AP mode.
- RavsirMay 11, 2022TutorOk that's interesting. I'll have to play with it more then. I managed to navigate to the ex7700 remotely through the network, but it was complaining there was no network to extend. When I started the genie, it wouldn't register the network it was connected to. I thought it was part of the r8000 brokeness so I took it out of the network and am just using the ds7800 and ex7700. Everything I want is kinda working, but every now and then the ex7700 just disappears, which it never did with the r8000. Seems I'm between a setup that occasionally drops the extension and a device that can't manage static IPs properly.
With the AP mode disabling guest networks, if I forward a guest network from my router, through an extender or an AP (as the primary network), does that defeat the security that the guest network provides in the first place?
