Bighead_sd's avatar
Bighead_sd
Follower
Jan 05, 2021
Can a WNR2000 router and CM400 modem be donated to a nonprofit organization?
I replaced the subject equipment.  i want to know if i'm able to donate the old equipment to a nonprofit such as the AmVets or Goodwill so someone will be able to use it versus throwing it them in the garbage.
  • plemans's avatar
    You can try. I'd factory reset the both before doing so.
    • plemans's avatar
      Or keep them as a backup in case of failure on the new devices. I always have at least 1 backup of my router and modem.
