DaveWC
Jul 04, 2016Tutor
Can access internet, but not router
Hi, I have a new R7000 router. I can access the internet from all computers, cell phones etc. but when I try to access the router from my main computer I cannot. It says "NETGEAR router is not found ...
- Jul 05, 2016
Kaspersky installs some deeply embedded drivers, so merely exiting it is not sufficient.
Try Netgear's instructions for dealing with Kaspersky (link). Many find, however, that these don't work, so uninstalling is the only option. For some reason, many find that things work after re-installing Kaspersky.
DaveWC
Jul 05, 2016Tutor
I didn't uninstall Kaspersky, but I exited it and tried it with no success. I also ran the computer in Safe Mode which does not run Kaspersky. All other computers have the same version of Kaspersky running.
TheEther
Jul 05, 2016Guru
- DaveWCJul 05, 2016Tutor
Thanks for everyone's help. I uninstalled Kaspersky, reinstalled & it works fine now. Thanks again.
