marcusmembrane's avatar
Apr 03, 2021
CAN ANYBODY TELL ME THE DIFFERENCE BETWEEN THE NIGHTHAWK MK-83 AND MK-63 BESIDES ABOUT $250 IN COST
I saw an advertisement for Netgear's Tri-band AX3600 3-Pack (MK83) for $499.00, and then saw Amazon had the AX1800 (MK63S) for $299. I read that the MK83 covers up to 6,750 square feet, and the older...
  • plemans's avatar
    Apr 03, 2021
    the MK83 system is a triband system with a dedicated wireless backhaul between router and satellites.
    that dedicated backhaul allows all the satellites to have much faster speeds and lower latency than they would otherwise.
    with the dual band mesh system, the satellites have to use the same chip to go router--->satellite and then satellite---->devices. and the chip can't do both at once. So its speed gets reduced significantly. The tribands are the fix for the lowered speeds because of that dedicated backhaul.
