zsmehta
Aug 02, 2021Follower
Can i assign static IP to a printer
microchip8
Aug 02, 2021Master
Static IP is set on the device itself. You're most likely asking for a Reserved IP on the router. If so, get the printer's MAC address and assign it an IP address
- michaelkenwardAug 03, 2021Guru - Experienced User
If you want to do that, the printer's control software is the usual way in.
