SPtotheA
Aug 22, 2021Tutor
Can I connect a second router for VPN use dedicated to my Roku only?
Just purchased a CM1100 modem, which I understand to be ethernet port aggregation capable, but I don't really know what this means as I'm pretty novice with anything other than a simple modem-->route...
- Aug 23, 2021
so go:
modem---->rax---->r7000
with the 3rd party firmware on the r7000.
Aug 23, 2021Guru - Experienced User
Depending on your isp, most ISP's (cox, comcast, spectrum) only support 1 device connected to the CM1100 or CM1200. Wan port aggregation is when the router can aggregate 2 wan ports to support speeds great than gigabit.
The R7000P and RAX40 (from your signature) don't support wan port aggregation.
So you can't have 2x routers directly connected to that modem unless you have one of the lucky few ISPs that support multiple devices (like sparklight).
Were you planning on installing 3rd party firwmare to the r7000P for the vpn or what was your intentention exactly?
Because you could always go
CM1100--->R7000P----->RAX40 (in access point) mode.
That'd allow you to have the r7000P as vpn. not sure of what vpn or their capabilities but some allow you to set specific devices to go through the vpn
- SPtotheAAug 23, 2021Tutor
I wanted to set up the R7000 (I don't have the "P" version) exclusively for the VPN and only to connect the Roku to it so we can watch our local baseball team since all streaming services dropped local Fox Sports affiliates. Everything else would connect through the RAX40 (my unit says RAX45 but the 40 is the only "RAX" option that came up - not sure if that matters or not).
Is that what you were asking?
The main issue I'm trying to avoid is when I set up our VPN on the router last time it blocked our kids from accessing things online for school.
- plemansAug 23, 2021Guru - Experienced User
I'm not sure of what 3rd party firmware you're using on R7000.
You might have better luck asking on the vpn providers forums on if its better to go
RAX---->R7000
or
R7000--->RAX
I don't have any firmware on it at the moment, but I would plan to use the VPNs firmware I suppose. Sorry, my novice is showing.
Do the two routers have to be connected?
