ASiddhu's avatar
ASiddhu
Initiate
Jan 14, 2022
Can I connect Nighthawk R7900 as an access point to Orbi mesh satellite (not the base)
I have a Nighthawk R7900P. I now acquired the Orbi WiFi6 (RBK852) with base and satellite. I still have a section of the house that does not get a good signal. I wonder if I can connect the Nighthawk...
  • ASiddhu's avatar
    ASiddhu
    Jan 14, 2022
    Thank you. That certainly clears it up. I was also thinking of connecting the satellite via a cable to improve the backhaul. And then connect the Nighthawk to it as AP.
