Winood's avatar
Winood
Can I have 2 routers in my house and extend my range by buying a second device?
Hi,
I have the X4 router in my livingroom, but got a studyroom in the attic on the second floor. The Wifi signal does not reach the attic.
I have a powerline (internet through electricity netwok) in the attic. I would like wireless internet in the attic. What ould you recommend? Any thoughts? I was thinking of buying a second nighthawk and by that, expanding the existing network. Do they work together like that?
Anyone out there for a helping hand?
Thanx
Winood
  • Yes, you can purchase a second router (an R7000 would be plenty) configure the R7000 as an Access Point (AP mode) and connect to your 7500 via powerline, With an R7000 in AP mode, you can use all the LAN ports on the router. Also, have a look at the EX7000, for price comparison. It supports AP mode, also.
  • michaelkenward's avatar
    michaelkenward
    What about adding a wifi powerplug to the existing network in the attic? Or add a wifi extender to the powerline network?
