Nittany24
Jan 17, 2020Guide
Can I repurpose a Nighthawk DSL Modem as a Wifi Router attached to by Cable Modem?
I currently have a Nighthawk D7000v2 VDSL/ADSL Modem Router. My DSL service connects to it and then it also is used as my wireless router. I am changing over to Cable and have purchased a Netgear C...
- Jan 19, 2020
I stand corrected!!! I got it to work. I choose "Other" and then went to the page and selected the Must use Ethernet WAN as you had previously instructed. THANKS TO ALL OF YOU! :)
duckware
Jan 18, 2020Prodigy
OK, so the illustrations in the manual are wrong (do not match the real physical router)!? The illustrations show no internet port (only a DSL port).
So, IF you see a read jack labeled "internet' on the back of your device, connect that to your new cable modem, and hopefully it will work.
duckware
Jan 18, 2020Prodigy
Nittany24, does your D7000v2 have a red internet port on it?
Well, this is all one big mess. According to photos Netgear itself submitted to the FCC for the D7000 (PY315200306) and the D7000v2 (PY316400356), the D7000 HAS a red internet port, but the D7000v2 does NOT have a red internet port.
D7000v2:
Label: https://fccid.io/PY316400356/Label/Label-Sample-and-Label-Location-Information-3358702.pdf
External: https://fccid.io/PY316400356/External-Photos/External-Photos-3358694.pdf#page=2
D7000:
Label: https://fccid.io/PY315200306/Label/ID-Label-Location-Information-pdf-2624639.pdf#page=2
External: https://fccid.io/PY315200306/Internal-Photos/Internal-Photos-pdf-2624640.pdf#page=1
- duckwareJan 18, 2020Prodigy
Search the V2 manual for "Must use Ethernet WAN". Looks like with this setting one of the LAN ports on the back gets converted to the WAN port (should be labeled?) -- which you then plug into your cable modem.
- antinodeJan 18, 2020Guru
> You can repurpose the D700v2 as an Access Point, but not as a router
> to your new modem.Doesn't _anyone_ around here read the User Manual?
> DSL port).Look again? The D7000v2 User Manual is lousy with errors ("red
Internet port", for example), but it does mention the "Internet WAN
port".> Search the V2 manual for "Must use Ethernet WAN". [...]
Or just trust the gizmo to do the right thing automatically.
