Nittany24
Jan 17, 2020Guide
Can I repurpose a Nighthawk DSL Modem as a Wifi Router attached to by Cable Modem?
I currently have a Nighthawk D7000v2 VDSL/ADSL Modem Router. My DSL service connects to it and then it also is used as my wireless router. I am changing over to Cable and have purchased a Netgear C...
- Jan 19, 2020
I stand corrected!!! I got it to work. I choose "Other" and then went to the page and selected the Must use Ethernet WAN as you had previously instructed. THANKS TO ALL OF YOU! :)
Nittany24
Jan 19, 2020Guide
Well I had sad news. Apparently the Xfinity tech is telling me that this D7000v2 is not compatible with Xfinity. We did a factory reset on the D7000v2 and when I went to the router login, unfortunately Comcast is not a provider in the drop down for me to choose. So I think I have to go buy a new router or get a modem that has a router built in :(
Nittany24
Jan 19, 2020Guide
- michaelkenwardJan 19, 2020Guru - Experienced UserThe idea that a router is not compatible with a particular ISP doesn't wash. Sadly, their tech people are famously ill informed and can't hope to know all the routers out there. That is what this place is for.
- Nittany24Jan 19, 2020Guide
Everyting is working beautifully in my home tonight. Thanks michaelkenward for following up.
