AcC8braman's avatar
AcC8braman
Follower
Feb 10, 2021
Can I run Nighthawk r8000 without ethernet cable to router
Hi,
Please forgive me if this is a really silly question:-
I have just bought a AC3200 as my house is built with stone so the walls are thick. Now, where the ISP router is, is a daft position, so having the netgear ethernet to it might not assist me.
I was hoping to place the ac3200 somewhere else and have it wirelessly connected to the ISP router - is this possible or it needs the ethernet cable plugged in all times?
Again, sorry if this is a daft question but I cannot find the answer trowling the internet?
Thanks
Steve
1 Reply
  • schumaku's avatar
    schumaku
    Hello Steve,
    Routers as primely built as routers, and can (more or less sophisticated) be re-configured to some Wireless Access Point mode.
    There are purpose designed Wireless Extenders for this purpose, however this requires an existing very good wireless coverage to about the half the way from where you want the other wireless coverage added.
    Said that, an AP does require a wired connection.
    A network cable does always make a much better connection than any wireless, especially on massive buildings.
    Does this help?
    -Kurt
