ageekgirl
Feb 23, 2021Aspirant
Can I set monthly Data limits per MAC address
Can I set monthly Data limits based on one of the PC in my household based on the MAC address? My son keeps down loading video games and exceeding our monthly Data.
Feb 24, 2021Guru - Experienced User
What actual router do you have?
You posted in the modem routers/modem section.
ageekgirl
Feb 24, 2021Aspirant
Thank you for asking. I had put it in and for some reason it disappeared. Its NightHawk X6S AC3000 model R7900P
- plemansFeb 24, 2021Guru - Experienced User
You wouldn't be able to. That model doesn't have device specific tracking (not many do) or even 3rd party firmware to support that option.
- ageekgirlFeb 24, 2021Aspirant
Can I set any Data limits. Because this is caused by my son down loading Video games maybe I can set another down load limit. I did see traffic limits in the control panel under advanced see below.
- michaelkenwardFeb 25, 2021Guru - Experienced User
The only way I can think of to deal with that is to use something like parental controls to block access to particular sites, and add those that supply games. But be warned that young persons are experts at finding ways around such obstacles.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Set Up Parental Controls.
You can also see if the ability to "block sites" works. (I haven't tried that sort of thing.)Netgear is making it harder to use the free version of Parental Controls. It wants users to take out a subscription to Circle, which gives you more control over what goes on. The good news is that the R7900P supports Circle. In your case, it might be worth the investment.
Circle® - Smart Parental Network Controls | NETGEAR
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk WiFi Routers
