flipr33983's avatar
flipr33983
Can I update firmware WITHOUT installing router?
I have a Nighthawk R7900P that I am not using, I'd like to connect to it, WITHOUT installing into my network. Since I lost my job to virus-related work slowdown, I want to update firmware, reset pas...
  • microchip8's avatar
    Apr 06, 2020
    Connect one of your PCs with ethernet cable to this unused router, go to http://192.168.1.1 and login with the credentials and do a firmware update. Afterwards you can connect your PC again to your router in use
