orbeavhawk
Oct 13, 2021Aspirant
Can I use a WiFi 6 Adapter and get WiFi 6 with my Modem/Router?
I would like to install a WiFi 6 Adapter in my computer but I fear that it will be a waste of money - because I don't think my Netgear Modem/Router will support it. I went to their Site to see if th...
Oct 13, 2021Guru - Experienced User
What actual modem/router do you have?
Wireless AX is a hardware change so if you only have an AC router, its not something that firmware will change.
And what adapter were you thinking off adding?
An intel AX210/AX200 isn't much more expensive than an AC adapter right now.
