orbeavhawk
Oct 13, 2021Aspirant
Can I use a WiFi 6 Adapter and get WiFi 6 with my Modem/Router?
I would like to install a WiFi 6 Adapter in my computer but I fear that it will be a waste of money - because I don't think my Netgear Modem/Router will support it. I went to their Site to see if th...
michaelkenward
Oct 14, 2021Guru - Experienced User
If you plan t replace the anonymous Netgear Modem/Router and ditch its wifi, you can put whatever router you want to use as a wifi source you like behind it.
The trick to getting that setup to work without problems, and using all of the features of your chosen router, is to work out how to put your existing Modem/Router into bridge (modem only) mode.
This is straightforward with DSL modem/routers.
Many cable modem/routers also support it. Dig out the manual for your device and look for a section with something like Cable Your Modem Router to a Router and Use Bridge Mode.
Is the Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
If you have a modem/router with AC1900 wifi, then you should be on safe ground. Most modem/routers that support there will happily support bridge mode.
- orbeavhawkOct 14, 2021Aspirant
THANKS so MUCH for taking the time to answer and suggest possibly the perfect solution too my dilemna. I'm a low income Senor citizen
so IF I could pull this off and keep the modem/router, which is the: Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0, this would be ideal. I don't think I have the Manual, if I ever did, will look....hopefully I can download it from their site. I am definitely lookinng into this GREAT Option, now that you have come to my "RESCUE" with this previously unknow information! GOD Bless YOU! Mixchael
- michaelkenwardOct 14, 2021Guru - Experienced User
First ask yourself what the problem is? Then ask will a new router fix it?
What Internet speed to do you pay? Why do you want faster wifi?
That is not a modem/router. It is one of those USB things that people use to connect a PC to the wifi.
To see what the model number of the modem is, look at the label on it. Something like this:
WHOOPS! Forgot to add the actual Model #: C7000v2. I dnlded the Manual and found all the pertinnent directions to BRIDGE it
as you told me and I believe that I would be aable too do this [if/when I decide to do it].
My present Interent Service fm Xfinity runs at @ 100Mbs......Reading alot about the potential speeds of WiFi 6 ... I was thinking that it may
solve some of my buffering problems at times when I am Streaming ALL of my TV Service, that is thhe main reason, but now that I have read further....I think I am "jumping da gun", in reality, looks like it will not really be able to really do what it is capable of for sometime? Whatever, this is so wonderful to now know that I will be able to go too WiFi6 w/o having to buy a new $500 Modem/Router! Have a GREAT Day! YOU have made my day alolt better - let me tell 'ya!
