orbeavhawk
Oct 13, 2021Aspirant
Can I use a WiFi 6 Adapter and get WiFi 6 with my Modem/Router?
I would like to install a WiFi 6 Adapter in my computer but I fear that it will be a waste of money - because I don't think my Netgear Modem/Router will support it. I went to their Site to see if th...
michaelkenward
Oct 14, 2021Guru - Experienced User
orbeavhawk wrote:
THANKS so MUCH for taking the time to answer and suggest possibly the perfect solution too my dilemna. I'm a low income Senor citizen
First ask yourself what the problem is? Then ask will a new router fix it?
What Internet speed to do you pay? Why do you want faster wifi?
orbeavhawk wrote:
IF I could pull this off and keep the modem/router, which is the: Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0, this would be ideal.
That is not a modem/router. It is one of those USB things that people use to connect a PC to the wifi.
To see what the model number of the modem is, look at the label on it. Something like this:
orbeavhawk
Oct 14, 2021Aspirant
WHOOPS! Forgot to add the actual Model #: C7000v2. I dnlded the Manual and found all the pertinnent directions to BRIDGE it
as you told me and I believe that I would be aable too do this [if/when I decide to do it].
My present Interent Service fm Xfinity runs at @ 100Mbs......Reading alot about the potential speeds of WiFi 6 ... I was thinking that it may
solve some of my buffering problems at times when I am Streaming ALL of my TV Service, that is thhe main reason, but now that I have read further....I think I am "jumping da gun", in reality, looks like it will not really be able to really do what it is capable of for sometime? Whatever, this is so wonderful to now know that I will be able to go too WiFi6 w/o having to buy a new $500 Modem/Router! Have a GREAT Day! YOU have made my day alolt better - let me tell 'ya!
- michaelkenwardOct 14, 2021Guru - Experienced User
orbeavhawkForgot to add the actual Model #: C7000v2.
Perfectly capable modem./router.
100 Mbps should not have buffering issues.
Even so faster wifi might not be the best option. If you have a decent and recent TV it may have a wired Ethernet port. If possible, plug from the router into that.
If not, where possible I use Powerline Ethernet. to use my household mains circuit as a substitute for running Ethernet cables all over the place. Easier to set up, and less fragile than wifi. Might even be cheaper
- orbeavhawkOct 15, 2021Aspirant
TKS! Sure appreciate learning of all this Tech stuff I never knew exsisted.
I presently run Ethernet connections to maybe 6 different components in my home theater - including my LG OLED TV, it was a PAIN
that's 4 sure running all those E. Cables. Had never heard of what you suggested and will now check that out too....did take a quick look and
did not like price of $84.....but need to check this out! Again.....Thanks!
