rakhulwen
Sep 05, 2022Follower
Can I use Nighthawk wifi 6 router as an AP if my main is a 5GHZ nighthawk R7450
I have a 2 year old Nighthawk R7450. We just moved into a larger split level home. The internet installer has my router downstairs in the middle of the house. Wifi got weak in parts of the upstairs...
microchip8
Sep 05, 2022Master
Yes
- michaelkenwardSep 06, 2022Guru - Experienced User
You can also do things the other way round.
If the Nighthawk wifi 6 router is more capable, use that as the main router and turn the R7450 into an AP.
You'll probably have to swap them around.
