rakhulwen
Sep 05, 2022Follower
Can I use Nighthawk wifi 6 router as an AP if my main is a 5GHZ nighthawk R7450
I have a 2 year old Nighthawk R7450. We just moved into a larger split level home. The internet installer has my router downstairs in the middle of the house. Wifi got weak in parts of the upstairs...
microchip8
Sep 05, 2022Master
Yes
michaelkenward
Sep 06, 2022Guru - Experienced User
You can also do things the other way round.
If the Nighthawk wifi 6 router is more capable, use that as the main router and turn the R7450 into an AP.
You'll probably have to swap them around.
