MKULLOHTX713
Jan 26, 2021Follower
Can I use the AC1900 C7000v2 Modem/Router as just a secondary Router
I am an ATT Uverse Customer and received the AC1900 C700 v2 as a gift, and am wondering if there is any way to use it as a secondary router and bypass the modem part of the device. If I hook it u...
Jan 26, 2021Guru - Experienced User
You could use it as an access point. There's a procedure writting up on how to do so for an C6300. Should be the same for the C7000
Can I use a C6300 cable modem without cable intern... - NETGEAR Communities
