Handgunz
May 04, 2022Follower
can' log in due to not answering 2 questions
I log in to router and then it asks two questions What is your oldest brothers name and what is your youngest. I'm pretty sure the answers are Gene and Chris but it says that is not right and will n...
May 04, 2022Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to routerlogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
