wadinyade
Dec 26, 2023Aspirant
Can my r7800 force all DNS traffic to use my Pi-Hole?
I have two Pi-Holes set up and while they work, I’m under the impression that some services and devices will fallback to hardcoded dns if they detect content filtering. I have seen references to rout...
Dec 26, 2023Guru - Experienced User
And you pointed the DNS configuration on the R7800 to your PI's? Under Advanced Tab/Setup/Internet there is DNS configurations there.
