cddthompson's avatar
cddthompson
Follower
Oct 30, 2020
Can Nighthawk X6S AC3600 be set up as a mesh?
I am satisfied with my router, but it sometimes drops the signal. Can I set up this router as a mesh system? If not, which extender would work best? I have a 3000 sq ft home with three levels and 50 smart home devices. I also use a VPN, so whatever solution needs to work with a VPN. We stream TV and have fast internet speed. Thank you.
