Damin69
Jun 09, 2016Tutor
Can no longer access the Log in on THIS computer
I can acess my router from all of my other machines exept this one. This is the machine I use all the time and I was able to access my router before. It just all of a sudden stopped being able to acc...
- Jun 10, 2016
Had to uninstal Kaspersky and reinstall and all started working correctly again.
IrvSp
Jun 09, 2016Master
Similar report from someone with Kaspersky. He had to remove it. You have it?
- Damin69Jun 09, 2016Tutor
Yes, I have always used it. I have it on all of my computers. I have always been able to acess it before, And can on all my other systems so not sure why this one is now not able when I have been able to before. I can try an uninstall and give it a try again.
- IrvSpJun 09, 2016Master
Found the other thread here, https://community.netgear.com/t5/Nighthawk-WiFi-Routers/One-Computer-Can-t-Login-To-R7000/m-p/1097814#M33496. Uninstalled, re-installed, all working fine.
Thanks all information helps. I found this after you had mentioned KIS possible issues. So on the Kapersky Lab forum some had similar issuse also. This is what I found.
https://forum.kaspersky.com/lofiversion/index.php/t332682.html
I will give it all a try when I get home tonight around 7pm. Will let you know if it works.
Thanks for the help.
Todd
