Damin69
Jun 09, 2016Tutor
Can no longer access the Log in on THIS computer
I can acess my router from all of my other machines exept this one. This is the machine I use all the time and I was able to access my router before. It just all of a sudden stopped being able to acc...
- Jun 10, 2016
Had to uninstal Kaspersky and reinstall and all started working correctly again.
Damin69
Jun 09, 2016Tutor
Yes, I have always used it. I have it on all of my computers. I have always been able to acess it before, And can on all my other systems so not sure why this one is now not able when I have been able to before. I can try an uninstall and give it a try again.
IrvSp
Jun 09, 2016Master
Found the other thread here, https://community.netgear.com/t5/Nighthawk-WiFi-Routers/One-Computer-Can-t-Login-To-R7000/m-p/1097814#M33496. Uninstalled, re-installed, all working fine.
- Damin69Jun 09, 2016Tutor
Thanks all information helps. I found this after you had mentioned KIS possible issues. So on the Kapersky Lab forum some had similar issuse also. This is what I found.
https://forum.kaspersky.com/lofiversion/index.php/t332682.html
I will give it all a try when I get home tonight around 7pm. Will let you know if it works.
Thanks for the help.
Todd
- Damin69Jun 10, 2016Tutor
