millertime23
Aug 24, 2021Aspirant
Can no longer VPN into port 443 on R7000
I had TCP port 443 configured for the openvpn settings on my R7000 router and it was working perfectly. After the firmware upgrade to v1.0.11.126_10.2.112 my VPN will no longer connect. I tried...
michaelkenward
Aug 25, 2021Guru - Experienced User
millertime23 wrote:
Does anyone have any possible solutions for this?
You could see if reverting to earlier firmware works.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Get the earlier firmware from the support pages for your device.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device.
millertime23
Aug 25, 2021Aspirant
Thanks for the feedback. I considered reverting my firmware to an earlier version. I'm only reluctant to do that because of possible security patches that may have been issued in the latest firmware
- michaelkenwardAug 25, 2021Guru - Experienced User
Your call. A VPN that might work versus a possibly useful security improvement.
You can check to see if the firmware caused the problem and then decide which way to jump.
- millertime23Aug 25, 2021Aspirant
I've been considering flashing DD-WRT if I can't find a fix for this. I prefer to keep stock firmware, but if I'm forced to downgrade firmware to fix this I'd rather install the latest DD-WRT instead
- michaelkenwardAug 26, 2021Guru - Experienced User
Your call. Unfortunately, this place doesn't support third party firmware and there aren't that many experts in that stuff.
I know that the firmware updates promise to fix "security issues" but the reality is that these issues may well be "theoretical" threats that have rarely, if ever, been seen in the wild.
A lot of people never get round to updating firmware and don't experience any obvious effects.
As ever, your call. But if you have any more diagnostic details beyond "Nothing is working." maybe someone can divine the entrails.
