millertime23
Aug 24, 2021Aspirant
Can no longer VPN into port 443 on R7000
I had TCP port 443 configured for the openvpn settings on my R7000 router and it was working perfectly. After the firmware upgrade to v1.0.11.126_10.2.112 my VPN will no longer connect. I tried...
michaelkenward
Aug 25, 2021Guru - Experienced User
Your call. A VPN that might work versus a possibly useful security improvement.
You can check to see if the firmware caused the problem and then decide which way to jump.
millertime23
Aug 25, 2021Aspirant
I've been considering flashing DD-WRT if I can't find a fix for this. I prefer to keep stock firmware, but if I'm forced to downgrade firmware to fix this I'd rather install the latest DD-WRT instead
- michaelkenwardAug 26, 2021Guru - Experienced User
Your call. Unfortunately, this place doesn't support third party firmware and there aren't that many experts in that stuff.
I know that the firmware updates promise to fix "security issues" but the reality is that these issues may well be "theoretical" threats that have rarely, if ever, been seen in the wild.
A lot of people never get round to updating firmware and don't experience any obvious effects.
As ever, your call. But if you have any more diagnostic details beyond "Nothing is working." maybe someone can divine the entrails.
